realkaka2204
[resolved]idm Vs Bitdefender 2012? Help Me
57 posts in this topic
After update a few minutes ago, IDM connection problems, solved.
Everything works perfectly, thanks to team work from Bitdefender!
<_< I will wait for an official release note on this forum before installing Bitdefender 2012 again. Thanks for the information!
Share this post
Link to post
Share on other sites
I am just updated my bitdefender to 2012.I am also facing same problem with IDM.
Edited by umer farooq
Share this post
Link to post
The links can't be resumed either
Can you be more specific please ?
Share this post
Link to post
This proplem is solved long time,so my work was interrupted.
Share this post
Link to post
Is very strange! on some sites, IDM - download allowing more connections. But the most is not possible to download multiple files.
Try to download this and you will be convinced that IDM works perfectly.\
I apologize if my statement sufficiently verified.
The first kit that I downloaded after the update yesterday, was that indicated above and found that everything is ok.
Edited by Gini™
Share this post
Link to post
Downloading this link Download. IDM has only one connection. Others are waiting for response.
Edited by svbk
Share this post
Link to post
one more problem is that I have to manually add new programs into application rules before I can connect to the internet. Please fix this
Share this post
Link to post
I DONT UNDERSTAND THE PROBLEM IS SOLVED OR NOT ??????????????????????????????????????????????????????
Share this post
Link to post
Hello,
The fix is not yet released as I have already announced in the other 2 topics discussing the exact same thing. Please check the forum before opening a new topic, creating multiple topics on the same issue is confusing for both me and the users reading the topic.
We have found the cause of the issue and escalated for resolution to the Dev. team. Until then, you can use the workaround I posted at the link below:
http://forum.bitdefender.com/index.php?s=&...st&p=117979
@Amour1991: please do not use CAPS, it is considered offensive and against our forum rules.
Regards,
Share this post
Link to post
Hello,
Regards,
Sorry , I meant no offence I am just confused .
I would appreciate it if you inform as soon as the fix got released .
Thanks.
Share this post
Link to post
Hello,
Regards,
Share this post
Link to post
pls tell me why do i have to pay hard earned dollars on some antivirus which needs to experiment why is this punishment , really dont understand ...................... have to wait 4 updates and have to wait untill the bid dev team does something abt idm or registry booster 2011 or slow connection or slow webpages .... why??
:wub: sorry i mean no offence this is not called as a responsible approach............
Share this post
Link to post
Dear support team,
I know I should post this message in other section but I had this problem and I have some other problems related to bitdefender firewall design! after I faced the problem which made stnair2000 angry, I downgraded my bitdefender and now I'm using IS2011, but IDM problem exists... I was impressed by power of bitdefender antivirus but the firewall's design is so annoying. for example in IS2011 it places IDL in a white list and define a full access rule for it but it doesn't work well at all. I've downloaded more than 70 GB this month by IDM, before bitdefender I had been using another security solution for 4 years, everything went fine and IDM worked perfect but my laptop infected with a ###### virus and I chose bitdefender.
IDM has 3 step to connect a server, first connecting..., second send GET..., third download receiving file...! before bitdefender these 3 steps take time about 3 seconds and just one time until finishing. In bitdefender it takes time about 30seconds and these 3 steps are continuing more than 1000 times!!! and it causes my download speed decreases. for example last night I started to download a file about 700MB and today it was stick in 500MB and all of IDM connections write send GET...!!!
I don't know what's your plan for this important issue but I think you'll loose a lot of your customers. as I said it's a big problem with all of bitdefender products. I'm in a trial period and this problem forces me to stop registering bitdefender :(.
Share this post
Link to post
everything works perfectly! Thanks Daniel!
Share this post
Link to post
Thank you, Problem is solved ( IDM download with 16 connections, ping is low(speedtest.net) ). However, time to load a website is longer. I try to reload a few times,everything is normal, sometime I can't load it.
Example: bongdaso.com, google.com, ict.net, start64.com(sometimes),...
Share this post
Link to post
I have exactly the same problem.
Very hard to open a web page, or not open at all. I uninstalled Bitdefender and everything works ok. I reinstalled the Bitdefender, and the version 15.0.27.325, all work ok.
After the update size 27733kb, Bitdefender switched to version 15.0.27.338 and problems occurred again.
It seems that the problem reproduces only on x64 systems.
Please fix the problem.
Regards,
Edited by Gini™
Share this post
Link to post
With what browser does this issue occur ? Please test it and let me know if you encounter it with all: Chrome, Firefox, IE.
All pages or just some ? Anything particular about those websites ? Anyone using 32-bits reporting the same issue ? ONLY AFTER the update to version 15.0.27.338.
Share this post
Link to post
Problem with nightly 9.0a1, IE 9.0. Some website is problem (bongdaso.com(always) , google.com.vn, vnexpress.net, bitdefender.com (sometimes),etc...). I'm using Win 7 Ultimate x64, Bitdefender internet Security 2012 build 15.0.27.338
Edited by realkaka2204
Share this post
Link to post
We're very very angry. Speed internet is very very low (download,...ect). If not fix, we will uninstall Bitdefender 2012 and install the another Antivirus software. We're disappointed about BIS 2012!!!!!!!!!!!!!!! :angry: :angry: :angry: :angry: :angry: :angry: :angry: :angry:
you are wright bitdefender 2012 very slow internet problem if you bitdefender is not solve this problem goto buy another antivirus
Share this post
Link to post
i install bitdefender total security 2012 in windows 7 service pack 1 32bit but sam problem slow download slow internet ple solve
:angry: :angry:
Share this post
Link to post
IDM problem is solved but I have the following problems after installing BD2012 :
1- Bittirrent download speed is decreased to a quarter (on the same torrent download : 220 kb/s >>> 45 kb/s)
2- Your freedom never start a connection to a remote server
After uninstalling BD2012 everything is OK . I'm using a fresh windows 7 64bit
Share this post
Link to post
The problem occurs on any of the browsers: Mozilla Firefox, IE9, Google Chorme and found that the problem persists and SRWare Iron. There are many sites that charge is extremely difficult or can not load at all. I mention: login mail account - yahoo, google.com, ... Very few pages open in one click.
I am firmly convinced that the problem arose with the last build .338
Thank you!
Edited by Gini™
Share this post
Link to post
Same problem here, as far as i see IDM problem has been fix but the speed slightly decrease, for IE, FireFox and other web browser i realize they run slower then usual. I am using 2 computer, each running BitDefender Internet Security 2011 and 2012 to see the different. After small observation, BD_IS 2011 loading much faster than BD_IS 2012. For search advisor, BD_IS 2011 check link (Google.com) much faster than BD_IS 2012. I hope this problem be fix ASAP. BitDefender has been my first choice for Security Solution over 5 years and if this not fix i will turn to my second choice. I Love BitDefender and i trust team can work better than we expected to deliver what user want to protect their PC and Sever.
Share this post
Link to post
Guest
This topic is now closed to further replies.
